HI,
I am not sure if this is possible for the Peplink Balance products, but even if it is not, maybe someone can help with a solution to achieve the same end result…
I have client software at different sites connecting to a central server, via a Peplink 310.
The client software software initiates a session on a specific port, lets say 2044.
Is it possible to allow the Peplink to direct all incoming traffic (to the server) to use port 2044, and all outgoing traffic to go out via a different port, such as 2045? For the same TCP session?
From what I read//understood, the outgoing balancing feature is only for sessions initiated from the server side. So if a session is initiated by a client to the server, the outbound policies will not apply as the session was initiated from a remote site.
The reason for this query is that I am using ISP’s with different upload speeds. So what I am ultimetly trying to do is that once a client in a remote location connects to the server, then all incoming traffic would go through the ISP with good download speeds, and all outgoing traffic to that client (which is still part of the same TCP session) will go through the ISP with faster upload speeds.
Any help or suggestions to achieve this another way would be appreciated…
thanks
