I work for a Company that has a Balance One with pepwave AC One minis. I am trying to utilize Captive Portal for our guests and can’t seem to connect to the public network.
I have followed instructions from the knowledge-base and requested assistance from our distributor, yet I am still unable to connect. It appears that every device connected to the public network is not acquiring an IP address, so I believed that DHCP was disabled. DHCP is enabled on the public network and the event logs shows devices connecting to the public network, even though the devices are not acquiring an IP address. I logged into InControl2 to check to see everything on its end was configured properly, and the configurations made in InControl2 has not changed since our distributor assisted us. Could it be that we have faulty hardware or Captive Portal still isn’t configured properly? I was told from our distributor that Captive Portals must be applied to VLANs and not SSIDs in order for Balance Ones to act as gateway for Analytics.
Can you provide the following info for us to assists further ?
What is the firmware version running for the Balance One & APs ?
May i know the physical connections for the APs & Balance One ? APs are directly connect to the Balance One LAN interface ?
Base on the description above, do you mean the main problem is guest users fail to get IP address when connecting to public network (Public VLAN) ? Do you tested with Static IP ? Will the Guest device with static IP get connected to the public network?
Beside that, do you try before disable the captive portal settings ? With captive portal disable the guest devices can get connected ?
the Balance One is running firmware 6.3.3 build 2526
AP is running firmware 3.5.3 build 1607
AP is connected to Balance One via Gigabit switch
I configured the guest devices with static IPs and successfully connected to the network. At this point, I am unable to communicate with the default gateway of the network.
Without captive portal settings, only 1 guest device connected while the rest were not distributed IP addresses.
1.)
Balance One has 2 VLANs created and the default untagged LAN. VLAN for testing (tag:5) and VLAN for guests (tag:20). ports 1-3 are defined for the untagged LAN. ports 6-8 are defined for the test network. ports 4 & 5 are trunked for any VLAN. the gigabit switch is connected to port 1 for the untagged VLAN.
2.) & 3.)
There are no VLANs defined on the gigabit switch. all switch ports are defined for untagged traffic.
4.)
2 SSIDs are defined for APs. SSID for the untagged VLAN and SSID for the guest network.
*Did connect APs directly into the Balance One, did not solve connection issue.
