I have a Pepwave Surf SOHO is a very simple configuration at home. I have about ten clients connected to the router, some wired and most wireless with a wired WAN connection. It is running 6.3.3 although I tried version 7 as well and still have the issue.
When attempting to add a new device to the wireless network, it would not get an IP address although it seems to join the network just fine otherwise. I checked the client list on the router and could see the client didn’t receive an IP address and defaulted to a locally assigned address (169.xxx.xxx.xxx). I then checked my computer. Same issue; it could not get an IP address. Thankfully my iPad still had access so I was able to access the router though the iPad.
Before I turned on DHCP debugging, I power cycled the unit. Same issue. I then reset to factory defaults on the web interface. I could barely get access to the unit because it would not serve up an IP address to any host except one. Even setting a static address on the host didn’t work. The SSID did change to the default so I could tell that it did factory reset.
Eventually I pressed the reset button for ten seconds to clear the config and could get one host to access the router. It was still having issues assigning DHCP addresses. I discovered DHCP debugging and checked the logs (see below)
Something isn’t making sense. After a factory reset, the lease pool was still full. My workaround is to add entries to the DHCP server and adjust the scope. I also tried to adjust the DHCP server TTL to 1 minute to clear out the client list. The phantom entries still exist.
Any ideas on how to do a full reset on the router to delete all the clients from the DHCP table?
Jun 07 06:32:17 DHCP Server: 192.168.50.1 lease pool is full
Jun 07 06:32:17 DHCP Server: In server 192.168.50.1, IP 192.168.50.240 is already using
Jun 07 06:32:16 DHCP Server: In server 192.168.50.1, IP 192.168.50.239 is already using
Jun 07 06:32:16 DHCP Server: In server 192.168.50.1, IP 192.168.50.238 is already using
Jun 07 06:32:15 DHCP Server: In server 192.168.50.1, IP 192.168.50.237 is already using
Jun 07 06:32:14 DHCP Server: In server 192.168.50.1, IP 192.168.50.236 is already using
Jun 07 06:32:14 DHCP Server: In server 192.168.50.1, IP 192.168.50.235 is already using
Jun 07 06:32:13 DHCP Server: In server 192.168.50.1, IP 192.168.50.234 is already using
Jun 07 06:32:13 DHCP Server: In server 192.168.50.1, IP 192.168.50.233 is already using
Jun 07 06:32:12 DHCP Server: In server 192.168.50.1, IP 192.168.50.232 is already using
Jun 07 06:32:12 DHCP Server: In server 192.168.50.1, IP 192.168.50.231 is already using
Jun 07 06:32:11 DHCP Server: In server 192.168.50.1, IP 192.168.50.230 is already using
Jun 07 06:32:11 DHCP Server: In server 192.168.50.1, IP 192.168.50.229 is already using
Jun 07 06:32:11 DHCP Server: In server 192.168.50.1, IP 192.168.50.228 is already using
Jun 07 06:32:11 DHCP Server: In server 192.168.50.1, IP 192.168.50.227 is already using
Jun 07 06:32:10 DHCP Server: In server 192.168.50.1, IP 192.168.50.226 is already using
Jun 07 06:32:10 DHCP Server: In server 192.168.50.1, IP 192.168.50.225 is already using
Jun 07 06:32:09 DHCP Server: In server 192.168.50.1, IP 192.168.50.224 is already using
Jun 07 06:32:09 DHCP Server: In server 192.168.50.1, IP 192.168.50.223 is already using
Jun 07 06:32:08 DHCP Server: In server 192.168.50.1, IP 192.168.50.222 is already using
Jun 07 06:32:08 DHCP Server: In server 192.168.50.1, IP 192.168.50.221 is already using
Jun 07 06:32:08 DHCP Server: In server 192.168.50.1, IP 192.168.50.220 is already using
Jun 07 06:32:08 DHCP Server: In server 192.168.50.1, IP 192.168.50.219 is already using
Jun 07 06:32:07 DHCP Server: In server 192.168.50.1, IP 192.168.50.218 is already using
Jun 07 06:32:07 DHCP Server: In server 192.168.50.1, IP 192.168.50.217 is already using
Jun 07 06:32:06 DHCP Server: In server 192.168.50.1, IP 192.168.50.216 is already using
Jun 07 06:32:06 DHCP Server: In server 192.168.50.1, IP 192.168.50.215 is already using
Jun 07 06:32:05 DHCP Server: In server 192.168.50.1, IP 192.168.50.214 is already using
Jun 07 06:32:05 DHCP Server: In server 192.168.50.1, IP 192.168.50.213 is already using
Jun 07 06:32:04 DHCP Server: In server 192.168.50.1, IP 192.168.50.212 is already using
Jun 07 06:31:56 DHCP Server: 192.168.50.1 lease pool is full
Jun 07 06:31:56 DHCP Server: In server 192.168.50.1, IP 192.168.50.211 is already using
Jun 07 06:31:56 DHCP Server: In server 192.168.50.1, IP 192.168.50.210 is already using
Jun 07 06:31:56 DHCP Server: In server 192.168.50.1, IP 192.168.50.209 is already using
Jun 07 06:31:55 DHCP Server: 192.168.50.1 lease pool is full
Jun 07 06:31:55 DHCP Server: In server 192.168.50.1, IP 192.168.50.208 is already using
Jun 07 06:31:55 DHCP Server: In server 192.168.50.1, IP 192.168.50.207 is already using
Jun 07 06:31:55 DHCP Server: In server 192.168.50.1, IP 192.168.50.205 is already using
Jun 07 06:31:55 DHCP Server: In server 192.168.50.1, IP 192.168.50.206 is already using
Jun 07 06:31:55 DHCP Server: In server 192.168.50.1, IP 192.168.50.202 is already using
Jun 07 06:31:55 DHCP Server: In server 192.168.50.1, IP 192.168.50.204 is already using
Jun 07 06:31:55 DHCP Server: In server 192.168.50.1, IP 192.168.50.203 is already using
Jun 07 06:31:54 DHCP Server: In server 192.168.50.1, IP 192.168.50.201 is already using
Jun 07 06:31:54 DHCP Server: In server 192.168.50.1, IP 192.168.50.200 is already using
Jun 07 06:31:54 DHCP Server: In server 192.168.50.1, IP 192.168.50.199 is already using
Jun 07 06:31:54 DHCP Server: In server 192.168.50.1, IP 192.168.50.198 is already using
Jun 07 06:31:53 DHCP Server: In server 192.168.50.1, IP 192.168.50.195 is already using
Jun 07 06:31:53 DHCP Server: In server 192.168.50.1, IP 192.168.50.197 is already using
Jun 07 06:31:53 DHCP Server: In server 192.168.50.1, IP 192.168.50.196 is already using
Jun 07 06:31:53 DHCP Server: In server 192.168.50.1, IP 192.168.50.194 is already using
Jun 07 06:31:53 DHCP Server: In server 192.168.50.1, IP 192.168.50.193 is already using
Jun 07 06:31:52 DHCP Server: In server 192.168.50.1, IP 192.168.50.192 is already using
Jun 07 06:31:52 DHCP Server: In server 192.168.50.1, IP 192.168.50.191 is already using
Jun 07 06:31:52 DHCP Server: In server 192.168.50.1, IP 192.168.50.188 is already using
Jun 07 06:31:52 DHCP Server: In server 192.168.50.1, IP 192.168.50.190 is already using
Jun 07 06:31:51 DHCP Server: In server 192.168.50.1, IP 192.168.50.189 is already using
Jun 07 06:31:51 DHCP Server: In server 192.168.50.1, IP 192.168.50.186 is already using
Jun 07 06:31:51 DHCP Server: In server 192.168.50.1, IP 192.168.50.187 is already using
Jun 07 06:31:51 DHCP Server: In server 192.168.50.1, IP 192.168.50.185 is already using
Jun 07 06:31:50 DHCP Server: In server 192.168.50.1, IP 192.168.50.184 is already using
Jun 07 06:31:50 DHCP Server: In server 192.168.50.1, IP 192.168.50.183 is already using
Jun 07 06:31:50 DHCP Server: In server 192.168.50.1, IP 192.168.50.180 is already using
Jun 07 06:31:50 DHCP Server: In server 192.168.50.1, IP 192.168.50.182 is already using
Jun 07 06:31:49 DHCP Server: In server 192.168.50.1, IP 192.168.50.181 is already using
Jun 07 06:31:49 DHCP Server: In server 192.168.50.1, IP 192.168.50.178 is already using
Jun 07 06:31:49 DHCP Server: In server 192.168.50.1, IP 192.168.50.179 is already using
Jun 07 06:31:49 DHCP Server: In server 192.168.50.1, IP 192.168.50.177 is already using
Jun 07 06:31:49 DHCP Server: In server 192.168.50.1, IP 192.168.50.174 is already using
Jun 07 06:31:49 DHCP Server: In server 192.168.50.1, IP 192.168.50.176 is already using
Jun 07 06:31:49 DHCP Server: In server 192.168.50.1, IP 192.168.50.175 is already using
Jun 07 06:31:48 DHCP Server: In server 192.168.50.1, IP 192.168.50.173 is already using
Jun 07 06:31:48 DHCP Server: In server 192.168.50.1, IP 192.168.50.172 is already using
Jun 07 06:31:48 DHCP Server: In server 192.168.50.1, IP 192.168.50.171 is already using
Jun 07 06:31:48 DHCP Server: In server 192.168.50.1, IP 192.168.50.170 is already using
Jun 07 06:31:48 DHCP Server: In server 192.168.50.1, IP 192.168.50.168 is already using
Jun 07 06:31:47 DHCP Server: In server 192.168.50.1, IP 192.168.50.169 is already using
Jun 07 06:31:47 DHCP Server: In server 192.168.50.1, IP 192.168.50.167 is already using
Jun 07 06:31:47 DHCP Server: In server 192.168.50.1, IP 192.168.50.165 is already using
Jun 07 06:31:46 DHCP Server: In server 192.168.50.1, IP 192.168.50.166 is already using
Jun 07 06:31:46 DHCP Server: In server 192.168.50.1, IP 192.168.50.164 is already using
Jun 07 06:31:46 DHCP Server: In server 192.168.50.1, IP 192.168.50.163 is already using
Jun 07 06:31:46 DHCP Server: In server 192.168.50.1, IP 192.168.50.161 is already using
Jun 07 06:31:46 DHCP Server: In server 192.168.50.1, IP 192.168.50.162 is already using
Jun 07 06:31:46 DHCP Server: In server 192.168.50.1, IP 192.168.50.160 is already using
Jun 07 06:31:45 DHCP Server: In server 192.168.50.1, IP 192.168.50.159 is already using
Jun 07 06:31:45 DHCP Server: In server 192.168.50.1, IP 192.168.50.158 is already using
Jun 07 06:31:45 DHCP Server: In server 192.168.50.1, IP 192.168.50.157 is already using
Jun 07 06:31:45 DHCP Server: In server 192.168.50.1, IP 192.168.50.155 is already using
Jun 07 06:31:45 DHCP Server: In server 192.168.50.1, IP 192.168.50.156 is already using
Jun 07 06:31:44 DHCP Server: In server 192.168.50.1, IP 192.168.50.154 is already using
Jun 07 06:31:44 DHCP Server: In server 192.168.50.1, IP 192.168.50.153 is already using
Jun 07 06:31:44 DHCP Server: In server 192.168.50.1, IP 192.168.50.151 is already using
