I have a Surf SOHO MK3 running firmware version 8.1.3(5030) that devices (Windows 10 laptops and Cell phones) are able to connect to the AP without issue as long as it is set to Broadcast the SSID. If SSID breadcast is disabled then the devices will remain connected but are unable to reconnect if the device is rebooted or the wireless NIC is disabled/re-enabled. As long as the devices present the correct password they should be able to reconnect. Has anyone experienced similar behavior?
