Hello I have a customer interested on purchasing either the Max HD2 dual 4g LTE Mobile Router versus the Max Single Cellular Router for Mobile Deployments
HD2 Dome.
Fox ex. what are the main differences between the two.
Are they both firstnet band 14 compatible?
Welcome to the forum.
I think we need a bit more detail here to help answer your original question. Which HD2 variant? Which single cellular MAX model? Assume the US, what sort of mobile? Man portable? PAtrol vehicle, police boat, command and control trailer?
The choice between them will come down to desired form factor and throughput. Personally I’m a big fan of the Transit Duo LTE-A Pro / CAT12 model as I think it hits a particularly good bang per buck target and its small, versatile yet powerful enough to do just about anything you need it to.
That said the HD2 has POE output on the LAN which is great for mobile CCTV installs, and has separate wifi radios for wifi wan which is better in command and control vehicles.
