We need to run some processes on servers behind a Pepwave Max, based on the type of active connection (Satellite/Wifi/Cell 1 or 2).
Does the Pepwave Max have some simple check you can do and see the type of active connection from a batch script?
Or a http call to the build in web server that respond with an xml and detailed info on connections?
I don’t want to ping to the outside world or a gateway, I am looking for an answer from the Pepwave device itself to prevent unnecessary satellite costs on continues ping checks.
Any help or inside is highly appreciated.
