Currently, positioning is not available with the Max On-the-go. Is it possible to retrieve via SNMP the GSM cell ID to which it is connected as well as signal strength and sync technology?
It would me greatly in the positioning of my devices but not only. It will be very useful for service monitoring and stability issues.
I would like to have easily this data in bulk for a full pool of MAX on-the-go so SNMP seems a good approch but reports in InControl2 are perfect too if exportable.
In short:
for each WAN:
absolutely needed:
signal strength
GSM CELL ID
Sync technology
super nice to have, these infos for other antennas visible by the modem:
signal strength
GSM CELL ID
Kr,
PG
