HI Support,
Somebody configure the Peplink’s demo unit become slave with configured sync, not able to disable it back.
Can someone help to disable the sync? I will need to demo for customer soon.
balancedemo.peplink.com
Thank you.
Regards,
Tony
HI Support,
Thank you.
Regards,
Tony
Hi Tony,
Thank you for bringing this to our attention. The config has been changed now, so it should be fine for your demo. Hope it goes well.
Steve
Thanks a lot Steve, it works now!
HI Steve,
The Peplink’s Demo went into configuration sync state agian.
Can assist to disable it?
Hi Jason,
This has been fixed (again) - thank you for bringing this to our attention.
Steve
