Defining multiple Speedfusion VPN profiles between the same endpoints
For different kinds of traffic, I want to create two tunnels between two endpoints (a MAX BR1 and a FusionHub) with different WAN Smoothing and FEC settings and use outbound policies in order to select the right tunnel for the right kind of traffic. The first tunnel is setup fast and easy, however, when using the same Remote ID for the second tunnel (with different name of course) I get the error “Remote ID: *** is already defined in other profiles.” Is there no (other) way to apply different WAN Smoothing settings to different kinds of traffic between the same networks? Thanks.
You want subtunnels.
Thanks again man! That hidden option behind the question mark was indeed what is was looking for.
