Define Native VLAN in Trunk Ports on B One 5G
Scenario - I have 3 Peplink B One 5G running in a Star topology (One Hub - Two End points) deploying multiple layer 2 VLANs.
I am trunking 4 VLANs between them and require the functionality to select a VLAN and define it as a Native VLAN in addition to carrying the other 3 VLANs.
So a command line approach to this would be as follows.
Switchport mode trunk
Switchport trunk native vlan 10
switchport trunk allowed vlan 20, 30, 40
In this case VLAN 10 would be stripped of its VLAN tag and pass through the trunk as untagged traffic, whilst passing VLAN 20,30 & 40 - the specific routing application I have requires this to function and I can replicate this on everything from Cisco/TP Link etc.
I have confirmed the application i have functions with just a single VLAN with the port setting in access mode.
Suggestion for implementation.
Select Port Type - Trunk
Select VLAN Networks - Custom
Add in Select Native - {present all configured VLANS and allowing user to select a specific VLAN}.
Result the Select Native VLAN would then be untagged over the interface.
Hoping you can help - or show me how.
agree- its sometimes necessary to be able to choose a vlan to be the PVID for a trunk, on a trunk by trunk basis.
Hello @phendrickse,
We can do this currently only by using an external Peplink (or third party) managed switch; the ability to use the network ports on Peplink routers as a fully managed switch requires further evolution, and your feature request makes a good case for it.
So, get a +1 from us on this request, too.
Happy to Help,
Marcus :slight_smile:
This gets a +1 from me, ran into this limitation on an SDX Pro I deployed when trunking to non-peplink switches. User-configurable native VLANs are always a good idea on trunks. Not sure why they aren’t supported here.
on sdwan devices, and even more so on the sd-switches
+1 from me , we could use this.
+1 from here
I’d support this absolutely - we’ve had to come up with creative solutions to this.
+1 here, would be very useful
Hello @Lai ,
Can Peplink consider adding this feature, “Define Native VLAN in Trunk Ports” to the next firmware release (such as Firmware 8.5.1 Beta 1 ), please?
Happy to Help,
+1 from me as well,
I’d didn’t even realise this wasn’t possible and would have caught me seriously out on an upcoming job!
+1 no brainer when a $30 router can do it with ease, why not PL?
Welp, adding a +1 here. Cannot efficiently integrate this in as an access switch in a predominately Meraki environment in a job we’re doing this weekend.
+1 from me as well. I can set the PVID on my SD switch, but not on the B One. Makes no sense.
+1 here, I think I mentioned this somewhere else too. Why would this feature not be included from the start?
Edit: just realized I already +1’ed this, but hopefully that conveys how strongly I feel about it lol
Not sure what else to do with this… I see there is some support from the community. Just not sure how to promote it further.
Hello phendricke i would create a support ticket as a wishlist to add this feature and adding this topic
+1 also to add this functionality
Hello @Giedrius.
Can you help bring this feature request to the development teams?
Have a good week,
+1 From me as well, it’s frustrating I can do this on an attached unifi switch, but not directly on the peplink routers.
Is this functionality coming??
I can’t confirm whether it is mate. I put the request in ages ago and have seen it supported by more than a few, plus elevated by Rising Connection. Based on lack of positive response or acknowledgement I guess it’s been relegated to the bottom of the pile or not considered worthy of implementation . :thinking::person_shrugging:
