I read that the default wifi password is the last 8 characters of the MAC address, which is supposed to be on a silver label. I think that is on the bottom, which is mounted to the wall.
Is there any other way to reset/access the wifi network?
Hi chovy,
there are some other ways to reset the wifi password.
connect your laptop with a LAN cable
Logon to the router and set a new password
use InControl2
change the Wifi there
use Remote Web Admin out of InControl2
set a new password
Best wishes
Dennis
