Decisions, decisions
Newbie here, engaged in building a camper van. News on the Ford Transit USA forum is that a Peplink is the hot setup for mobile connectivity. Less info on which model might be suitable (there are so many). And most of the descriptions are for only one product: not much in the comparison department.
Can anybody point me in a direction where I might find out more information? Product comparisons would be particularly helpful. The first cut at a possible purchase has me trying to decide between a MAX BR1 Mini 5G and a MAX BR1 Pro 5G. Any opinions? Comparisons? Further info? Topics I ought to be considering?
Thanks in advance
I would recommend contacting a Peplink Partner as they are likely the most efficient source for assistance in this.
If you are in the US then I have a couple of partners with whom we’ve had very good experiences (though none such in the camper van domain - that’s not the focus of our organization’s needs).
PM me if you’d like those $0.02.
Cheers,
Z
you can compare the options here: Peplink.com - Model Comparison
The Balance series is the office devices, Max is the rugged/mobile series.
So the BR1 Mini 5G is a fair bit slower than the BR1 Pro 5G in terms of throughput, its really intended more for IOT type applications. It also does not have wifi.
If you have the space, the B One 5G may well be suitable as well.
Excellent! That comparison page is exactly what I was looking for. Nicely done, too. I’ll be studying it. Thanks much
Peplink Partner? That one’s new to me. OK, I’ll check them out. I’ll PM you for the deets.
