As per peplink support the unit for Data is Gibibytes, but it is showing as GB which causes misunderstanding.could you please update the display units to GiB, MiB, etc.?
@Zener_Support can you share more on the issue you are facing with us? Which “Data” are you referring to? Maybe a screen capture could tell us more…
@WeiMing the data consumption showing in the reports. please find the screenshot for your reference.
