Hi, it would be great to have daily data usage on cellular connections available greater than 30 days. Is this data stored anywhere or is it offloaded at the 30 day mark?
The reports can be downloaded via CSV download link to allow you to keep the reports.
Beside that, you can also use Incontrol2 API to integrate with your application to store the reports.
https://www.peplink.com/ic2-api-doc/
