Daily Bandwidth Allowance Monitor - MAX
Hi
Is it possible to have a daily bandwidth allowance monitor. Currently we can only set monthly - however in India all operators offer a daily plan in a monthly package. Most commonly 1GB per day.
Sawan
Hi Sawan:
If you’re using InControl 2, that can give Daily (and even hourly) Bandwidth reports.
I hope that helps!
Jason
I think Sawan is looking for the ability to measure bandwidth usage during the day, cut off when limit is reached then reset at midnight so the following day’s allowance can be consumed…
Hi Martin
Yes exactly as all plans here are daily - if the data gets exhausted then everything stops working. This way we can alert them when it crosses 80% so they know it’s the Data.
Thanks Jason … we are currently monitoring on IC2 but no way to set alert.
Sawan
+1 this request. I need to limit daily data usage by MAC address. Rogue processes can exhaust monthly data allocation (30 GB) in a few hours. Ouch!
