Hope someone can help.
Power went out to my D-Link DES 1008PA, since then l have no internet on the rockus units that are connected to it . I do have connection via the LAN and the peplink local antenna…
Anyone???
Anyone???
Hi Alan,
if your Switch (D-Link) has no Power and your WiFi Antennas are connected to this device, then your Rockus Units are offline.
Happy to hear, that your online with Peplink. I don’t know what kind of Peplink device you’re using, if you have an LAN-Port unused, you can connect one of your Accesspoints to this.
Give us a little bit more infomation then you will get more help
Regards
Dennis
