Is there any incompatibility with this device (Dell Sonicwall NSA 4600) to create VPN ?, because communication can not be established
regards
regards
Can you open a support ticket here for us further check on the configuration done for the IPSEC VPN ?
Thank You
Regards,
Sit Loong
This is from over a year ago. Was support able to find a solution?
We have a lot of customer running IPSEC VPN with Sonicwall without issue. This is more on the IPSEC inter-operation configuration between Peplink devices and the third party VPN device.
Although Peplink official support Juniper & Cisco device, please open a support ticket if you facing issue establish IPSEC VPN between Peplink devices with third party IPSEC device and we will help to diagnose the issue.
Thank You
