Creating an L2 point to point tunnel on IC
Is it possible to create a L2 point to point Speedfusion tunnel between two B ONEs for example through IC2?
When Creating the point to point, are the Find my Peplink IDs also used or only the public IPs?
Thank you for the help,
Maciej
Hey Maciej,
I’m pretty sure that InControl takes what it knows about both devices to try and create the L2 tunnel. So WAN IPs are used and the IC2 detected IPs also.
