Is there a way to control which ports have PoE on the Max HD4 when using only one PoE activation kit? Currently only ports 1-4 are supplying PoE regardless of which port I connect the PoE power supply to, and I’m trying to activate PoE on ports 5-8 instead without requiring a 2nd poe kit.
For current hardware revision (1 and 2), this feature is by hardware design. With single PoE kit (regardless which DC Jack is connected), only LAN Port 1-4 can supply PoE output. If you need LAN Port 5-8 to supply PoE output, then you need to add second PoE Kit.
