hi there,
We use a Peplink Balance 210 Rev.4 with firmware 7.1.0 build 3433
The Peplink acts as a network gateway with Lan subnet set to 172.16.31.0/24, but it doesn’t resides in the real internal network.
Instead it communicates with a router which is set as gateway for the real Lan 10.10.100.0/24
Thus the router is between networks 172.16.31.0/24 and 10.10.100.0/24 but it doesn’t perform NAT, just forwarding ip packets.
So Pepelink receives the traffic with the original source IP but the content filtering doesn’t work, the rules do not apply and the clients have normal Internet access.
At first i thought it fo some kind of bug where the Peplink doesn’t perform content filtering for IPs that do not belong to it’s Lan network.
But this is not the case. I removed the router and set the Peplink Lan directly to 10.10.100.0/24 net.
The content filtering does not work either.
The only case that it works fine is when I enable Peplink’s Lan DHCP server but this unfortunately cannot be implemented in my case because DHCP is served by my local Domain Controller.
Am I doing something wrong? Is there a fixup or some earlier firmware version that Content Filtering is working fine for all routed traffic?
kind Regards.
