We are using the user group and content filtering.
Here is a requirement and not sure how to do it on Peplink:
Corp network
Allows - Update Sites
Block - Audio-Video
Guest Lan
Block - Update Sites
Allow - Audio-Video
How do we set the above up ?
Thanks.
You can achieve one of them (either update sites or audio/video) by blocking it with content blocking & then setting the relevant group that should be allowed as an exception but unfortunately the rules aren’t flexible enough for different exception types.
Depending on what specifically you want to block/allow in each category you might be able to use Outbound Policy to blockhole domains, or use bandwidth control to limit speeds to 1kb/s
