Surf AP 200 (Router)
Firmware Version: 9.0.44
Hardware Version: 1.5
I have had my Surf for over a year now and have never before had any problems. It is a great product.
Recently I have been attempting to set up reserved DHCP addresses for a couple of reasons; one being to set up QOS in the hope that it will make the voice quality on my Magic Jack VOIP more reliable.
I wasn’t sure at first if the IP address I selected should be in, or out of the reserved DHCP address range. I tried both and the out-of-range address (i.e. 192.168.20.9) seemed to be correct.
However whenever I tried I would suddenly have problems with any of my other devices connecting to the Surf. They would either not connect at all, or connect; spend a long time obtaining an IP address; and then usually lose connection and try again. (Pre-existing connections would stay up.)
The weird think is, these were not the devices I was setting the reserved DHCP up for. In fact I eventually realized that I could add a DHCP entry using a MAC address for a device that was completely disconnected,
and, after I saved the CPE setup, other devices (both wireless and ethernet) would have trouble (re)connecting. Rebooting the Surf never helped.
Once I lost my computer’s existing connection and could not get any access to the Surf until I pushed the factory-reset button on it. I then reconfigured from scratch; got everything working again; tried adding one reserved DHCP address, and it immediately acted up again.
My Surf’s AP is a Verizon 4G Mifi and I have an 8 port switch plugged into the ethernet port.
Any help would be greatly appreciated,
Jess Goodman
State College, PA
