dear all i am starting to use peplink prodruct.
can i get information is it possible to do Pepvn between balance BPL-710 MAX BR1 MK2 LTE.
i want to us Max BR1 to interconnect 30 site by vpn with the main site that have balance 710.
thanks in advance !
Hi aboubacar:
Welcome to the forum!
Yes, absolutely you can create PepVPN between a B710 and a BR1 MK2.
dear Jason
thank you for your feedback .
i can do it without any additional licence
Hi aboubacar:
Correct, baseline PepVPN is standard with all Peplink gear and again should not be a problem. It’s the higher levels of SpeedFusion that additional Licenses start to factor in for the BR1
