Users can now connect to SpeedFusion Cloud with Internet Security by Check Point. Doing so improves the security posture of your network by adding a number of security features. To get started, connect to the Web UI and navigate to the SpeedFusion Cloud, and then click Choose Cloud Location
Then you can choose a SpeedFusion Cloud Location that is protected by Check Point. Click the drop-down menu to choose a Location:
On the “Protection” column, you can set whether to enable Check Point protection. Click the green check box to save this profile.
The check mark in the “Protection” column indicates that the Cloud Location is protected with Check Point Internet Security. Click Apply Changes on the top right hand corner to save your changes.
