I have a Surf Soho, latest version hardware and firmware. When I connect to it via L2TP over IPSec, i get an ip such as 192.168.1.50 and my internet connection works. However I am unable to connect to other 192.168.1.* ips that are on that LAN.
What do I need to do to be able to connect to ips on that LAN?
I don’t think it is that. To me it seems like the vpn server isn’t creating the proper routes. My traffic is going to the soho, i can use the router admin and use the internet just fine.
ping testing is not an empirical test, because if on the other side there is a PC with windows active firewall, you will never be able to contact it via ping.
it happened to me that l2tp was not working properly, trying to disconnect and reconnect the connection the request was able to get to the destination
you can try to install wireshark both on your pc and on a pc connected in the soho LAN, and see if there are any requests and some replay .
