Have a MAX BR1 Pro 5G with multple WAN inputs (cellular, wifi and Starlink via the WAN port). Also using SFC protect. Have been unsuccessful in connecting via OPEN VPN. As part of troubleshooting, have disabled all WAN inputs except one, reset OPENVPN settings to just the one active source and redownloaded OpenVPN file from the status page. Unsuccessful in connecting to the system no matter which individual WAN input is active nor when SFC Protect is disabled (redownloading config file each time). Basically the OpenVPN client tries to login (going to the correct IP address) , then times out with a Transport Error, socket protect UDP.
I’m using the default UDP setting (1194) and have also set UDP1194 and TCP 443 and 943 to be open from any to any in the firewall. From the log, it looks like the max BR1 is rejecting the connection for some reason.
Log file extract below, open to any ideas/suggestions on how to get this to work as the ability to remotely access the network was a big part of why I purchased the Peplink unit.
—Log file—
[May 4, 2023, 10:52:16] EVENT: RECONNECTING ⏎[May 4, 2023, 10:52:16] EVENT: RESOLVE ⏎[May 4, 2023, 10:52:16] Contacting 30.90.217.43:1194 via UDP
⏎[May 4, 2023, 10:52:16] EVENT: WAIT ⏎[May 4, 2023, 10:52:16] WinCommandAgent: transmitting bypass route to 30.90.217.43
“host” : “30.90.217.43”,
“ipv6” : false
⏎[May 4, 2023, 10:52:16] Transport Error: socket_protect error (UDP)
⏎[May 4, 2023, 10:52:16] Client terminated, restarting in 2000 ms…
⏎[May 4, 2023, 10:52:18] EVENT: RECONNECTING ⏎[May 4, 2023, 10:52:18] EVENT: RESOLVE ⏎[May 4, 2023, 10:52:18] Contacting 30.90.217.43:1194 via UDP
⏎[May 4, 2023, 10:52:18] EVENT: WAIT ⏎[May 4, 2023, 10:52:18] WinCommandAgent: transmitting bypass route to 30.90.217.43
“ipv6” : false
bottom of file after 40 seconds of repeated efforts to login
⏎[May 4, 2023, 10:52:44] Transport Error: socket_protect error (UDP)
⏎[May 4, 2023, 10:52:44] Client terminated, restarting in 2000 ms…
⏎[May 4, 2023, 10:52:45] EVENT: CONNECTION_TIMEOUT SOCKET_PROTECT_ERROR : 30
CONNECTION_TIMEOUT : 1
N_RECONNECT : 29
⏎[May 4, 2023, 10:52:45] EVENT: DISCONNECTED ⏎
