I am currently in progress to evaluate if Peplink 580 is the right product for us to pool and load-balance the different WAN links we have to make better use of our available bandwidth.
I read that there’s multiple LAN ports for this model, would it be possible to setup e.g.
LAN 1 for Corporate LAN and LAN 2 for Guest LAN
Internet traffic for LAN 1 get load-balanced to all the WAN uplinks while LAN 2 only get to use specific WAN link
The reason for this is that at the moment Guest LAN has its own dedicated WAN links which most of the time there isn’t much traffic on it.
If we can pool the WAN links together, it could serve as extra bandwidth for corporate users, but we don’t want Guest LAN to negatively impact the utilization for our corporate users.
Thanks for your prompt advice. At the moment we are not using VLAN actually, is this a must when configure multiple LAN? On the Balanced 580, I am seeing physical LAN ports.
Both Corporate LAN and the Guest LAN has their own respective firewalls. And we have 3 WAN uplinks altogether.
We are planning to use drop-in deployment on WAN 1 with Corporate LAN as we have a number of existing services hosted within.
But generally we can make changes on our Guest LAN firewall in order to connect as LAN 2 on the Peplink.
Could you advise the correct configuration in this scenario? Many thanks.
P/S: What’s the difference between priority and overflow algorithm by the way? They looks very similar to me.
For the network design, we will recommend to deploy all WAN connection in NAT mode as this will allow B580 to have all the connected clients info for the Corporate network & Guest network. You can refer to the attached screenshots for the different type of the deployment.
PS: For Drop in mode (WAN1) that using public IP range, WAN extra public IP address is require for the Guest firewall.
Priority algorithm
Traffic will be routed through the healthy WAN connection that has the highest priority. Traffics load will not be monitor for the WANs.
Example Priority rule:
WAN1
WAN2
WAN3
Traffics will only forwarded to WAN2 only if WAN1 is down.
Traffics will only forwarded to WAN3 only if WAN1 & WAN2 is down.
Overflow algorithm
Traffic will be routed through the healthy WAN connection that has the highest priority and is not in full load. When this connection gets saturated, new sessions will be routed to the next healthy WAN connection that is not in full load.
Example overflow rule:
WAN1
WAN2
WAN3
Traffics will start to forwarded to WAN2 if WAN1 is over 90% utilize.
Traffics will only forwarded to WAN3 if WAN1 over 90% & WAN2 is over 90% utilize.
