I want to use my Surf SOHO in my camper to Capture the often weak WIFI from the RV Park and re-transmit inside my RV.
It has three antenna jacks that appear identical (A, B, C). I don’t see any markings indicating which one I would attach an external, directional antenna too?
I wanted to mount the antenna outside my camper on the roof pointing at the park’s Access Point, but still be able to broadcast the wifi inside the camper.
I assume I just replace one of the short antennas with the proper COAX cable and External Antenna? Which antenna port would I use, and do I need to change anything inside the router?
