I will be living in rural Mexico, and the only connections available are 2 Mbits DSL… I’m planning on getting 2 of those DSL connections.
If I understand correctly, I can connect those 2 DSL routers via ethernet to the Balance. Then configure the 2 IPs of the routers in the Balance’s control panel, disable DHCP on the routers, and let Balance handle DHCP, balancing, DNS, etc.
Is that right?
Is it that simple or are the any more complicated technical aspects I’m not considering?
Thanks in advance
