We provide WIFI from the IT department of the city in the vehicles with peplink routers. As the city uses Cisco components, we have to connect a Cisco AP to our routers. If possible, it would be nice, instead to use a additional AP, to connect the internal AP (for example form a HD4MBX) to the Cisco WLC that the AP can be managed by the IT department.
Whilst both Peplink and Cisco (and quite a few other vendors) may use CAPWAP for managing their APs there is no way this will ever happen.
I’d just decide which is less painful for you, either putting a Cisco AP in the vehicle and joining it to the remote WLC or using InControl2 to manage the Peplink APs themselves.
Thank you
Then I stick with the Cisco AP’s.
