Configuring the OSPF Cost for Each Interface
As of Firmware 6.3, you can configure the OSPF cost of each interface and PepVPN Connection using advanced mode. This enables disaster recovery: the branch office can connect to data centers in different locations. This ensures that the site can access HQ resources even if the main server goes down.
To begin, please navigate to Network > OSPF and select an area or create a new one.
From there, click the question mark icon next to Interfaces and than click the link that appears.Then, select the interfaces you want to establish custom costs for and then specify the desired OSPF cost.Click Apply Changes for your changes to take effect.
HI Alan,
Thanks. This looks good.
We need to control the OSPF cost of the the PepVPNs. We have two PepVPNs from every site, and need one advertised into the backbone area with a lower cost than the other.
I see that you offer custom cost on physical interfaces, but not the PepVPN interfaces in the example.
Regards,
Dana
You can define the OSPF cost inside the PepVPN Profile since firmware 6.3.0.
2 posts were split to a new topic: Define the OSPF costs for PepVPN’s that are created via inControl
