Hi
My customer is a company that operates machines remotely.
Background to this request
→ They would like to dynamically change SpeedFusion’s connection points based on the API.
Request Point
→ They would like to configure SpeedFusion settings via the API using the POST method.
We do this today using the InControl2 API.
We dynamic VPN and tags on the device to tell it which tunnels to connect to.
Should the InControl2 API still be used for this purpose if I need to dynamically change the SpeedFusion VPN WAN priorities for a certain profile between two of my own Peplinks? I see a way to get and update the general WAN priorities using the Peplink Router API, which can be seen on the main Dashboard page in the web interface, but not for a SpeedFusion VPN… I’ve looked at both the Peplink and InControl2 APIs:
https://incontrol2.peplink.com/api/ic2-api-doc
Thanks in advance ![]()
