Suporte Team,
I suggest that in incontrol2 is possible to put the Guest Portal for SSID rather than using the same for all AP registered in Incontrol.
For example:
If the client has two registered devices in Incontrol 2, rather than the same Guest Portal for all equipment, he set up the Guest Portal individually for each SSID.
Thank you.
