I need to recommend you to add feature for alerting users in case of any configuration error on Peplink.
for example everyday we face configuration mistakes like setting both LAN and WAN side on the same IP range and then customer calls support and says my port forwarding not working !! please put some kind of configuration error alerting on the dashboard to warn users about their mistakes on configuring the device.
