I have been managing Peplink MAX BR2 Pro from the device, but I would like to start using InControl. However, when I turn it on, it overwrites my config. I have the device set up the way I want it, so how do I import that config into InControl
Simply putting the router in InControl2 should not push any configuration to the router. It’s likely there are settings or a bulk configuration created in the InControl2 group. If you’re looking to start using InControl2, one way to start fresh would be to create an entirely new organization and start over. A less heavy handed option would be to create a new group within your existing organization, move the device to the new group and delete the old group.
Entire configurations can only be added to InControl2 through the bulk configurator, but more commonly, aspects of the configuration like outbound policy, firewall rules, and WiFi settings can be configured from the group or device level in IC2 and pushed that way.
