The MAX BR1 PRO is set up and working well. It routes on only a single WAN, a cellular connection. Connecting to it’s broadcast SSID works successfully.
Now in the process of adding the AP One AX Lite to extend the range of the network. The AP is wired to an unmanaged switch, which is wired to the Max.
Upon initialization, the AP One AX Lite has its own network, which I can connect to and successfully route to/from Internet.
In the configuration for Mesh in both the Max and the Lite, I inserted the same name as the SSID that the Max has configured, set both flags for 5 Ghz radio, and inserted the shared key. Both configurations match. I have not tried using an SSID that is new and discrete between the two devices.
Should this configuration work to extend the network using a single SSID?
Ideally, the network configuration is determined by the Max (i.e. DHCP and DHCP reservations) for all devices connected to the network ?
Also, it appears that the mesh needs to select and use only a single radio - do I understand that constraint correctly? Many thanks!
