I currently have only one BPL710 and would like to implement HA, but the 710 has been discontinued. Would it be feasible to pair it with an SDX for HA? Or are there other recommended models?
If you want configuration to sync between the HA Pair (so slave gets auto updated on primary config change) then they need to be an exact pair.
If you just want HA you can use any device that supports VRRP (from any vendor).
