Compatibility with Teltonika RUTX12
Hello everybody, this is my first post here asking about the compatibility of Mobility antennas with Teltonika RUTX12.
I think the most suitable partner to this specific router would be the Mobility 42G, but I want to install it on the trunk of my Mercedes W140 sedan.
My questions is, would Mobility 22G and 20G installed together work for this dual modem RUTX12? One of the GPS units will not be connected since I only have one socket. I couldn’t find any other comparable router with dual modem load balancing which can simultaneously use 2 sim cards to maximize internet speed.
Thank you beforehand for your replies.
Pretty sure it would be fine yes, though I’d suggest just double checking Teltonika are using the same type of SMA/RP-SMA connectors on each of the antenna ports.
That might actually be a better solution than the 42G as it would allow you to get some separation between the two antenna arrays for each carrier.
Really?
Peplink Transit Duo Pro is basically pretty much identical type of device albeit with better Cat12 LTE modems in it and a significantly better option for bonding / link aggregation than anything you can get from Teltonika in my experience.
Here are some:
BR2
BR2 Pro
BR2 Micro
Transit Duo pro
UBR Plus
Dome Pro Duo
Dome pro Long Range
HD2 MBX
MBX Mini
