Hi Everyone,
Is there any compatibility matrix / chart where only certain models of access points are supported by routers?
I have a Balance 20x Hardware revision 1 and the new AP one AX. But I am facing issues in configuring the AP one AX as access point managed by balance 20x? So trying to figureout if there is any compatibility issues.
Davis.
Hi Davis,
We’ve done this, and have one running in our workshop too.
However, I’d recommend you manage your wireless config in IC2 and push to the group rather than locally. Enables more features, and easier control too.
b20x can manage ap one ax
Thanks for confirming
Thanks everyone. the Ap One AX works fine with my B20x HR1. I issue was the lan port was set to access instead of trunk
