I have a BR1 with an AP1 wired directly to it. I have a mobile data plan and also a public Wi-Fi connection configure. Can I specify that my work laptops use the mobile connection and force kid devices to use the wifi as wan?
Sure. Create an outbound policy that says any : any enforced over public WIFI. That rule will send everyone’s traffic over public WIFI.
Create a new one above that has your laptops IP address as the source: any as destination and create a priority rule with cellular at the top and public wifi under it.
Then just create a DHCP reservation for your laptop to make sure its IP doesn’t change.
Save and apply and you’re done.
Thanks that did the trick
