Clarification on access v. trunk LAN ports
I’m surprised at how many conflicting opinions are out there on this subject. Just to be clear, I am referring ONLY to Peplink routers (not Cisco, etc.), and only to physical LAN ports (Ethernet). My routers are all B-One models.
Here is my understanding (correct if wrong, please) and questions.
My understanding:
  1. Access ports accept and send only untagged packets (no VLAN) externally (to/from the LAN port out on the wire).
  2. Packets entering the port from the wire are VLAN tagged as per the port’s configuration for traversing the router (internally) or trunk links (externally).
  3. Only packets VLAN tagged per the port’s configuration are passed from the router out to the port/wire, and at that time the VLAN tags are stripped from the packets.
  4. Trunk ports can accept or send any tagged or untagged VLAN traffic, as per the port’s configuration.
Questions:
  1. What happens if a VLAN tagged packet is received at an access port?
    a) Does it matter if the VLAN tag matches the configuration of the port?
  2. If I have an Ethernet port configured for a VLAN, and I have “Inter-VLAN routing” disabled, can a device on this Ethernet port see ANY device on another VLAN (or the default, “private” VLAN)? Or are their packets routed only to/from the Internet or to/from a properly configured Trunk port/link?
My goal is to connect some IoT devices via the LAN ports rather than WiFi due to their bandwidth requirements (streaming devices). I don’t care if they see each other, although I believe I can set them on separate LAN ports for further isolation. I have used a separate VLAN via WiFi in conjunction with “Block all private IP” in the AP setup with good results, but I want to confirm isolation using the LAN ports as well.
Thank you for your help in furthering my understanding of this concept and the security capabilities of my routers.
Beuford
Hi! Yes your understanding is correct.
On your questions:
  1. This packet is then dropped and not routed further. It doesn’t matter if the VLAN tag matches.
  2. It can’t see any traffic or reach/be reached by hosts from other VLANs. Traffic originating from this VLAN will only be routed through the WAN ports.
