I am trying to implement the use of Cisco Umbrella for MAX BR and Transit devices. According to Cisco documentation this should be any easy task using their API to send dyndns updates.
Well, this way I end up using their public DNS 208.67.222.222 and 208.67.220.220, right. I wasn’t specific enough in terms of my goal: What I want to do is to use their cloud based content filtering system. And in order to use that feature you need to authenticate yourself ahead of time, either by using a dedicated ddns client (for Windows or Linux) or by using the stated https:// request to updates.opendns.com like all other ddns providers.
Unlike in other routers I can’t configure a https:// request to match the criteria. So it would be great if either that was possible in the future or if OpenDNS (Umbrella) was among the ddns providers preconfigured on the Peplink devices.
