Hi all -
I plan to use a Balance 20 in my home network to manage two WAN connections: (1.) Verizon 4G LTE and (2.) DSL
I have sufficiently high data cap on the 4G LTE service to use it for most inbound and outbound internet activity for the clients in my LAN.
For routine cloud backups and mass data movement, however, I would like to be able to selectively choose the DSL connection when needed for this purpose. The speed is significantly slower, but there is no data cap (within reason).
How is this done? Do I create rules on the router interface, or can I select/assign a WAN connection to be used for specific IP addresses in my LAN (and be able to switch between WANs as desired)?
Thank you in advance for your insight -
- Ian Campbell
Cambridge, VT USA
