Dear colleagues,
Is is possible to choose an specific Mobile Network Operator within an eSIM?
I just purchased and installed one on my B One 5G, and I noticed that the eSIM doesn’t allow for custom Operator settings. Only “Auto” mode.
Thanks a lot,
Ignacio
Can you share a screencapture? Are you referring to the peplink esim?
Hi Jonathan,
I don’t have the router right here, but yes, I am referring to the Peplink eSIM.
I’ll send some snapshots later.
Thanks a lot
You can use the ? next to Carrier selection.
Then do either Manual selection or specify the plmn number in order for the carriers.
Thanks a lot, Jonathan
It is pretty clear now. I appreciate your help on this.
