Dear Team
We need to change some balancers that are in a group from uncontrol to organization. How can we do it?
Dear Team
If I understand correctly, you want to delete some devices that are in a group, in an existing organization.
You then want to add them to a new organization, correct?
Step 1, Login and click on ‘Device Management’ under ‘Organization Settings’:
Step 2, check all the boxes on the left:
Step 3, click on ‘Remove’ under ‘Actions’:
Now you can add the routers to a new organisation.
Ok, thanks.
