I have the Max BR1 Mini with an ATT and Verizon sim card. I had defaulted to Verizon sim card, but we have moved locations and there is NO Verizon service. I can’t access remotely through Incontrol because I am not hooked up to the internet through this device.
I need to change to ATT (or set to both/best). I have my cell phone hotspot that works, so I’m online, but not sure how to get remote access to change this settting
Ok, I went and purchased a LAN connection. I plugged into computer and into the LAN and console port (actually tried them both). Still not sure what the next steps are.
I have incontrol2 up on my computer, but still don’t have an option for remote access.
I probably should be doing something different, just don’t know what that would be?
Hmm. You purchased a LAN connection?? [That’s a bit of a non sequitur.] I’m afraid I really don’t understated your configuration or what you are trying to accomplish.
I think I’d recommend you engage the Peplink Partner from who you acquired the product. Any help there?
