since public IP Addresses are getting rare, we need the functionality of using several FusionHubs behind 1 IP-Address. Separated by Ports.
Example:
IP1, Port 4500 = FusionHub1
IP1, Port 4502 = FusionHub2
IP1, Port 4503 = FusionHub3
etc…
Is this possible already or planned?
Thanks for feedback.
Kind regards
Johannes
Yes, this is supported.
You need to make sure the followings is defined for each FusionHub Instances and the SpeedFusion Profile.
- Unique handshake port for each FusionHub Instances.
Custom handshake port for SpeedFusion Profile
PepVPN/SpeedFusion per Profile
Custom data port for SpeedFusion Profile
Thanks a lot. We have tested it successfully in first instance.
