A request has been presented to us that would be an improvement on the cellular bandwidth allowance monitor.
The thought is that rather than disconnecting the SIM or allowing just management traffic, allow a configurable throughput. this would help curb overuse and allow users better control over their SDWAN options.
You can do this using traffic limitation, API’s (zapier with https notifications if you can’t code ) or tunnel bandwidth limits.
Bandwidth limit is not available per se per modem, you need to build it
