I’m using a Max Transit Duo (2 modems). On modem 1 I have 2 AT&T SIMS. I would like to use both SIMS evenly throughout the month. So, if I use 100GB in total I’d like 50GB to use SIM A and 50GB use SIM B (or there about). In this case should I use the “Both SIMs” option?
In modem 2, I have a Verizon SIM in slot A and a T-Mobile SIM in slot B. Currently I’m manually switching between the two SIMs because I need to also change the network mode to Verizon when using the Verizon SIM and Generic when using the T-Mobile SIM. Is there a better way to handle this?
A variant for modem 1, in case you don’t have specific usage caps you want to address, is to automatically switch the two SIMs in the middle of the billing period:
