Evening All
Would it be possible to have SIM settings stored in a router (and IC2) which are related to a SIM card and automatically loaded to a slot when that SIM in inserted to the slot?
This would allow SIMs to be changed without having to log into the router and reconfigure a slot.
Main settings that would be required are;
-APN, username & password
-SIM PIN
-Bandwidth Usage on a particular SIM card
-Roaming Enabled/Disabled and country specific list
-LTE / 3G
-Frequencies
Another thing would be to add a weight setting to a SIM card so that if a SIM card has a higher weight value, it is the priority SIM card and if they have the same weight, they will change between normally (relating to SIM A/B, not modems)
Thank You
